maules.com wrote:I measured the Maule flap handle at 15" from forward end to hinge bolt.
However the length of the section behind the hinge bolt would also come into play.
Anybody have a description of BH flap mechanism ?
Hey Jeremy,
I didn't measure it, but forward of the hinge point must be about 15". I guessed 12" earlier from memory, but having been and looked, it is definitely more than that.
Of course - like you say, the short bit under the floorboards is also important. As are the horns at the wing root, and the drives at the flaps themselves. All those effect the mechanical advantage.
The splitter tang (Maule may not have this!) from the handle's cable to the individual flap cables also has some effect, because the length of pull changes there due to the Y-cable geometry.
Basically, the system starts from the handle, which connects to a cable which runs aft beneath the floorboards, which then splits into two cables behind the aft bulkhead using a tang. These cables run over pulleys to the flap horns in each wing root, which drive the flap actuators via independant torque tubes (one in each wing). The drive is simply a pushrod connected to the torque tube using an arm arrangement.
