Question....weight of
Wed May 28, 2008 11:35 pm
Does somebody know how much C 90-12 weighs?
where is data base on engine specs listed for cont. & lyc.
thanks
glaciercub offline
322
The Good Lord does not deduct those days from our alloted quota, spent fishing, flying or with our Grandchildren.......
Wed May 28, 2008 11:39 pm
CONTINENTAL C-90-12F Dry Weight 169 lbs
Output 95hp
R.P.M 2475
Dimensions H28.75 x W31.50 xL31.26 inches
Your welcome
mr scout on Thu May 29, 2008 12:05 am, edited 1 time in total.
mr scout offline
774
Wed May 28, 2008 11:43 pm
so how about 0200 ? read an article about comparison between the two and seems C90 come out better as to power-weight ratio
and true Hp. output at rpm.... ??
You still headed this way soon ?
glaciercub on Wed May 28, 2008 11:53 pm, edited 1 time in total.
glaciercub offline
322
Wed May 28, 2008 11:48 pm
Thats Patrol guy thats headed your way, I wish it was me as well.
Here is your 0200 answer
Dry Weight 188 lbs
Output 100 hp
R.P.M 2750
Dimensions H23.18 x W31.56 xL28.50 inches
mr scout on Thu May 29, 2008 12:06 am, edited 1 time in total.
mr scout offline
774
Wed May 28, 2008 11:50 pm
sorry for mix up..... and thanks for info.
take care
glaciercub offline
322
glaciercub wrote:so how about 0200 ? read an article about comparison between the two and seems C90 come out better as to power-weight ratio
I think you might find that the C-90 is a better engine if it is allowed to turn a long prop (taildragger or seaplane), but the 0-200 is better turning a shorter prop, but at higher RPM, C-150 for example. Seems like Continental knew what they were doing?
a64pilot offline
1398
Hey Mister Scout-- From what mysterious source do you find these engine specs?
2999
- Aircraft: None
Thu May 29, 2008 11:19 am
I didn't know it was mysterious
You know I have always shared any knowledge I have, the delivery isn't always the best but I share none the less.
mr scout offline
774
Thu May 29, 2008 11:23 am
I haven't looked, but all that and more would be in the TCDS for any engine.
a64pilot offline
1398
That link has a chart which starts at the O-200. C90 & smaller not shown.
Anyone have a power-setting chart for an O-200 handy? I was curious what horsepower it makes at 2475, where the C-90 is making 95. I'd guess around 80-ish. easy to see why the C90 turns a big prop better. Different cam grind makes the difference I guess.
Eric
10608
I think that link shows current production and I think your right about the cam. I looked for a C-90 powered C-120/140, but ended up with a C-85. I don't know if you will find a dyno chart for those old engines or not. Parts are readily available for the 0-200, but I think are getting scarce for the 85 and 90. Also I think the 0-200 has provisions for turning a vacuum pump which I think is rare on the others.
My impression is that the C-90 has more grunt to get off of the ground and climb, but the 0-200 is a little faster in cruise. MTV has flown them both back to back I think. What type aircraft are you putting an engine in?
a64pilot offline
1398
Sorry, that was glaciercub not hotrod150. Still which airframe?
a64pilot offline
1398
Was told by great source...(Clyde) that 0200 at 2500 is only putting out 75 ponies..... so 90 is way to go. Now I take Clydes word as gospel but was searching for stats which include weight etc.
If one keeps things light, no elect and such the 90 would do as well as 115 or125 considering weight and output. Togather with the right prop.....
glaciercub offline
322
forgot to answer your question "64"
it a L-18C........
trying to stay under 900 pounds but it's getting hard.
Have gar-aeros and can't go BW's yet with pocket book.
Seems everything I do cost ##
glaciercub offline
322
Sorry, me stupid. Where does a guy get a comparison matrix of all Continental engine models including the old ones?
2999
- Aircraft: None
This is how this all started, I was looking for same thing..
kinda got the info I needed but in a long about way? GREAT sight for answers!!!!
I too still havent found graph-chart ? of engine specs either
and from what I hearing they dont include 65-75-85 & 90s
p
glaciercub offline
322
Fri May 30, 2008 12:04 pm
IF you can keep it light enough is the hard part. you just have to replace some of the heavier parts with those made from unobtanium
Your not going to put electrics in it are you?
a64pilot offline
1398
Needle, Ball and airspeed..... oh wait, I dont have a ball?
No elect..... no frills, do have extended baggage and
a few lil. things to make hauling things a little easier.
take care
glaciercub offline
322
Zane,
I don't think you will find dyno charts for those old engines. I've found some, but they were from people that build spec engines and are somewhat suspect in my opinion. If you find a reputable one let us know.
a64pilot offline
1398
