Ford Wilson wrote:It seems to make sense that the guy that builds a plane should have sufficient knowledge to maintain the plane and sign it off. With that said, I am surprised that in Canada, it is basically the same rules HOWEVER, if you buy a homebuilt you are still allowed to maintain and sign it off even if you had zero experience in building that plane or any other! As restrictive as Transport Canada can be, this decision is strange. Chaulk one up for the FAA.
This is my first post here, so please take it easy on me
The main reason that the owner of the homebuilt in Canada can do the sign offs, and not the guy that built it is liability.
When a homebuilt plane is sold, all the liability is passed to the new owner, otherwise, if the plane is sold 10 times over 20 years, then crashes, the original builder would still be on the hook for the cause.
Canada has much different liability laws than the USA. In Canada, if a homebuilt were to crash, and the cause was found to be caused by the constuction of the aircraft, then the last person who certified the plane airworthy would be liable, which is the owner.
In the USA, if the same where to happen, I believe everyone, right back to the company who printed the paper for the assembly instructions "could" be found liable.
