Backcountry Pilot • Re-swaging O-300 pushrod tubes
15 postsPage 1 of 1
Has anyone used the beading tool that ATS sell to re swage the pushrod tubes. I need to start chasing some oil leaks and the pushrods look like the biggest culprit. I dont want to buy the tool and go to the hassle of doing it if its not going to help the leaks. Thanks for the info!
Jeredp offline
Aircraft: Cessna 172
Re: Re-swaging O-300 pushrod tubes
I've never seen the ATS tool, but I had good results from the Snap-on tool on several cylinders spread across 4 engines.
Dale Moul offline
Dale
Gravity Strikes Again.
Made one years ago.... Can get some pics of it if you want to make your own...
Brian
Brian-StevesAircraft offline
Pavement scares me..........
Dad's SPOT page
Dale Moul wrote:I've never seen the ATS tool, but I had good results from the Snap-on tool on several cylinders spread across 4 engines.
Do you by chance have the snap on part number?
Brian-StevesAircraft wrote:Made one years ago.... Can get some pics of it if you want to make your own...
Brian
Pics would be great! If it's easier to email, [email protected].
Thanks guys!
Jeredp offline
After having the rubber boot slide back from the lifter assembly 2x (resulting in 1 forced landing with 5 psi oil pressure and 1.5 qts of oil in crankcase) I went with the realgasket.com push rod tube kit solved that problem. Then resealed the thru bolts helped too. Selling the 170 w/O-300 and buying a plane w/O-470 cured alot of other problems :D
Glidergeek offline
Aircraft: 1968 P206C
DG 400
"Push rod housing tool for Continentals. It stops oil leaks. part number EL-91 only $59.50" per a 15 or 20 year old El Reno Aviation brochure I have. I tried googling a website for them but no luck. Maybe they're not around anymore, or maybe just old school and no website.
I bought the tool. Works great.
buzzlatka offline
I fooled around with O300 pushrod tubes for ages to stop the leaks as did another guy with another old 172 on the same airfield. I became somewhat of an expert in doing them.
In both cases, on both aircraft, the problem was actually caused by partially blocked crankcase breather tubes. Whenever I see an O300 leaking oil, it is the breather that is causing the problem. Mine was that hard to clean I ended up making a new one. The easiest test is to wipe the end clean with a rag, hold a finger over the hole in the side and see if you can blow into the engine.
aussie bob offline
My A-75 was leaking horribly around the tubes so I re-swaged them at last annual and the tool worked great. I'm assuming it's the same thing that the OP is talking about.
nefj40 offline
Aircraft: 2016 cessna cub
I don't have the Snap-on part no. the tool was OLD last time I borrowed it and that person has since retired. I can't find it on Snap-on's current website so it is probably discontinued. But if you can find one they work very well.
Dale Moul offline
Dale
I just got a call from John Craig in Sun Valley (he follows this forum but has never registered), He has 1 of the El Reno Aviation tools that you can borrow for the price of postage. =D> Give him a call at 208-726-7487.
Dale Moul offline
Dale
Dale Moul wrote:I just got a call from John Craig in Sun Valley (he follows this forum but has never registered), He has 1 of the El Reno Aviation tools that you can borrow for the price of postage. =D> Give him a call at 208-726-7487.
Just got off the phone with John and he's shipping it tomorrow! Thank you so much!
Jeredp offline
Tom offline
Aircraft: PA-18 7EC C-172
I purchased the ATS tool and it worked great, stopped the leaks first try,
N9PW offline
Aircraft: CarbonCub EX
My home made tool...
The trick with re swedging is to not expand the tube too much at the original swedge... They can crack and create more of a problem... I will tighten the original just a little, then adjust my tool no more than 1/8 inch from the original location and make a second swedge.... Have to be real careful to not get the balls off of the cylinder flange and screw up the tube but I have not had one leak after doing that...
Brian
Dad's SPOT page
15 postsPage 1 of 1
