Backcountry Pilot • Really cool experimental Stinson
35 postsPage 1 of 21, 2
I saw this bad ass Stinson at Palmer airport today. This must be a really fun and unique machine. I saw Doug Keller double slotted fowler flaps, full span slotted wing, control cables and tubing moved for huge baggage, lycoming GO 480 with what looks like a twin bonanza prop, big tires and probably lots more. Anyone know this machine?
PAMR MX offline
Re: Really cool experimental Stinson
Wow! Very cool!
bushpilot490 offline
Aircraft: C-175 with 180hp conversion
The GO-480 is the only detraction as far as I can see ($$$)....but wow, I bet she performs! There's a Stinson in ANC that has a leading edge from Charly Center on it and an O-470....I've seen the flight test results... incredible!! I wish they'd have kept working on getting the STC approved!!
JH
hardtailjohn offline
glacier offline
Whoever built it must be a John Deere fan.... :lol:
That is sweet. I'd love to talk to the builder about his plane. I have a homebuilt Stinson, that I've been working on for 5 ish years.
Lots of cool mods on that guys plane, and they are all mods that I have thought about, but didn't want to do, because I didn't want to take forever to build this plane.
mmartin1872 offline
FindMeSpot URL: http://share.findmespot.com/shared/face ... rdxTuiNhdo
Stinson 108-2
Stinson 108-3
Taylorcraft BC12D - Project
Starduster II
Thorpe S18
Piper Clipper
Poorman's 180 - Project
hardtailjohn wrote:The GO-480 is the only detraction as far as I can see ($$$)....but wow, I bet she performs! There's a Stinson in ANC that has a leading edge from Charly Center on it and an O-470....I've seen the flight test results... incredible!! I wish they'd have kept working on getting the STC approved!!
JH
If some wants 1 or 2 of those 480's with big 3 bladed props I have a couple!! Very inexpesive?? :shock: :mrgreen:
It is an Allsworth creation!
M6RV6 offline
This is really cool! Couple years back I was working with a DAR to try and built a experimental Stinson. Would have been cool if it had worked out.
Love it!
Is that the same allsworth that owns alaska aircraft engines? Which I believe also bought the o470 stc for the stinson?
mmartin1872 offline
Stinson 108-2
Stinson 108-3
Starduster II
Thorpe S18
Piper Clipper
Very cool aircraft.
It would be interesting to know how much difference those flaps make, being such a short span and a heavier aircraft than your typical Cub?
I would love to be able to afford to have Mr. Keller build a set for the Bearhawk, and see how they perform on a wider span. Maybe one day...
mtv wrote:Whoever built it must be a John Deere fan.... :lol:
Or Oregon Ducks! :) Awesome machine either way.
Matt that sure looks like an Allsworth machine, they have a few modified with big baggage doors and L/H rear cabin door like that one.
tar_stinson offline
mmartin1872 wrote:Is that the same allsworth that owns alaska aircraft engines? Which I believe also bought the o470 stc for the stinson?
Related
M6RV6 offline
Pretty awesome Stinson, someone put a helluva lotta work into it. I wonder if it's experimental - amateur built or experimental- exhibition?
There used to be a yellow and black Stinson (don't recall the dash number) in one of the open hangars at Auburn WA with an experimental placard on it. Other than squared-off tail feathers, it looked pretty stock. I did talk to the owner once & he told me the 165 Frank in it had car pistons or some such. Again, dunno if E-AB or E-exhibition.
Really cool is that a back door on L/H side in flaps picture ? The GO-480 should be more than enough -I'd go for a IO-540 myself ,or maybe just a "O" .
182 STOL driver offline
It's e-ab..
mmartin1872 offline
Stinson 108-2
Stinson 108-3
Starduster II
Thorpe S18
Piper Clipper
Looks to me like they took the engine and prop straight off of a Helio H-295
This is one in my shop for annual...
Brian
Brian-StevesAircraft offline
Pavement scares me..........
Dad's SPOT page
I know the non-geared O-435 is considered kind of a boat anchor, but I wonder why Lycoming never produced a non-geared O-480. It would fill a hole between the 360 & the 540, and would be comparable to the iconic Continental 470.
What's the horsepower on the GO480-- 270 or so?
hotrod180 wrote:I know the non-geared O-435 is considered kind of a boat anchor, but I wonder why Lycoming never produced a non-geared O-480. It would fill a hole between the 360 & the 540, and would be comparable to the iconic Continental 470.
Isn't the 540 comparable to the 470? Very similar hps. 235 vs 230 for NA and both 260 for injected. Is there much of a hole to fill for a 480??
