Fri Jan 30, 2009 11:09 am
Okay, I'm reading posts about two different materials!
Lexan is a trade name for polyester (PET). Plexiglas is a trade name for acrylic plastic. They both pretty much look the same, though Plexiglas has somewhat better optical properties than Lexan.
Lexan is mechanically stronger than Plexiglas, and can even be cold formed even bent using a metal brake without cracking. If you tried that with Plexiglas it would snap in a heartbeat. Both are thermoplastics and can be heated and shaped of course. Lexan is much more impact resistant than Plexiglas and is even used for bullet proof (resistant) barriers when thicker or laminated. There is some concern about using Lexan in aircraft side windows if it is firmly fixed in place and that window is expected to function as an emergency exit.
Lexan is softer than Plexiglas. If Lexan gets scratched, I don't know of a way to use Micromesh or polish to remove the scratch. Scratches in Plexiglas, and even crazing and cloudiness if it's not too deep, can be successfully polised out. If doing so with a machine, it's important to keep termpertures low.
As another poster mentioned, Lexan is available with a scratch resistant coating. It's also available with a UV light resistant coating, as uncoated Lexan doesn't do UV as well as Plexi.
Disclaimer - this is info from my noggin that is at least several years old. Things may have changed since the data was acquired as I do not have automatic software updates enabled.
bumper
