I flew my first X-country yesterday and noticed that I have a very slight left roll. After getting back I made an ajustment to the rigging. If it's rolling left and required right stick pressure then the left aileron should be rigged a little down and the right one a little up correct??? This is what I did and it didn't seem to really fix it. With my feet on the floor and the slight right stick pressure to maintain wings level my ball is centered so I don't think it's a rudder issue. The flaperons actually have some positive incidence in them. It gives you a little better cruise speed and the ability to pitch trim the aircraft by adding or taking out a little bit of flap.
Do we have any rigging experts that might be able to shed some light on this. Right now my left flaperon is at +2 degrees and my right is at +5 and it's still wanting to slightly roll left. I have verified the washout is the same on both wings and when the airplane is leveled per the manual both wings are level. Am I missing something? Thoughts?? Here's a shot of the airplane if your having a tough time with the Flaperon concept.
