Backcountry Pilot • Rotax 912 prop strike question
3 posts • Page 1 of 1
I'm looking at possibly purchasing a ground looped airplane. It has a 912ULS (100hp) with under 60 hours on it TTSN. In the ground loop, after hitting the wing, it was nearly stopped but it nosed up and broke one of 3 blades off the prop while at idle.
Anyone with experience with the 912 on here?
Thanks,
Jay
jaydub offline
Aircraft: Rans S7 "short tail" 100hp
Re: Rotax 912 prop strike question
http://www.flyrotax.com
Go here and you can download the MM.
redacted offline
Aircraft: Cessna 170
Thank you. I did that and now have the procedure to check.
Thanks,
Jay
jaydub offline
