mtv wrote:I'd run a little higher manifold pressure, but 1900 rpm and 21 inches works just fine, and they'll run there all week.
mtv wrote:Note that on the big turboprops, for example, the props typically turn somewhere around 1800 rpm, rarely much faster. Props that turn slow are much more efficient at turning horsepower into thrust, which is the name of the game.
shortfielder wrote:I usually fly reduced power settings with an O-520/C66-90-2. Not in any hurry, less fuel I burn=more time I get to fly. 16-17"s MP, 2300 RPM. I have the idea that the engine is working easier at these lower settings by turning a little higher RPM and less tendancy for lugging/detonating.
I was out flying yesterday and playing with this a litle. I do see a little gain in speed and reduction in fuel burn by dropping the rpms down around 2100, temps seem fine, engine is running smooth. Is this fine, any risk to the engine? Can I safely run lower rpm's in the 15-17" MP range? The bottom of the green on my tach is 2200.
Thanks Gary
shortfielder wrote: possability of causing harm to my engine(pponk O-470-50).
