Backcountry Pilot • rudder pedal needed
rudder pedal needed
6 postsPage 1 of 1
rudder pedal needed
Hi f4phantom here, I'm looking for a c-120 right side, right pedal with toe brakes
f4phantom offline
pedal
f4:
Have you a part number? If so try Cessnaparts.com
Is yours so bad that it can't be repaired? Sixty year old parts are often scarce and can be very expensive.
Quail offline
The truth will set you on the path to being free
You'll do better on the 120/140 assn site. Some aircraft are being parted out there.
a64pilot offline
If you go to Cessna, look for the new style composite pedals. They were $85 a set a few years ago, and can be fitted to most Cessnas.
Hey, let me dig around, I may have right and left sides off a 54 Cessna 180, not sure if they are the same?
C ya, Bub
Skylane offline
rudder pedal update
Hi guys,
thanks for the tips on finding rudder pedals. I went to central aircraft parts yesterday and found a pair that will interchange. they wont match exactly with the left pair, but as it is a club plane and no show plane that is not a concern. Thanks again for the replies.
f4.
f4phantom offline
6 postsPage 1 of 1
