Flight:
Most if if not all Back country strips are daytime VFR only . Many moons ago I flew all night long from a 1200 ft. Strip -runway lights courtesy of "smudge pots".Lit them up at sundown and put them out following morning . The flagman carried a similar pot on end of
11ft. flag pole . Later on (after one too many fires in fields ) flagmen would carry a 11ft. flag pole with one of those blinking yellow lights. I installed a few of the "construction sawhorses " with lights at the ranch ---Just turn them when you leave and it'll be lit when you get back. One side will do just land to the left or right .These should do http://www.brandonsafetylights.com/solarpowered.htm . Do it several times during the late afternoon to get down before attempting it at night. Put RED light on both ends to say land after this point and stop before this.Use the SPOT landing method per Mountain Flying Bible.It also helps to have 296 or better to "see " the terrain at night. I also have several thousand hours flying with Night vision goggles in helicopters , "0" depth perception but decent visibility in darkness. I don't like cross country flights at night - locally within 50 or so miles are ok. Usually much smoother at night .
