Backcountry Pilot • S7LS coming to a hangar near me.
30 postsPage 2 of 21, 2
Re: S7LS coming to a hangar near me.
courierguy wrote:for the 912 line of engines. PM me if you want a 72" Luga, I have in stock, I'll probably be at a buddies hangar today with one and will take a picture.
Is it the 102 series? Just curious.
Tom, will that work with the Warp HP hub?
Pete
pouellette offline
Aircraft: RANS S7S
CHEROKEE 140
I would also so suggest a larger diameter balance tube between the carbs. Hal can take care of that for you too. Pretty simple, quick, and inexpensive. It will let you comfortably reduce the idle, making your landings shorter without such aggressive breaking and shutdowns less violent. My static idle now is around 1000rpm.
shortfielder offline
shortfielder wrote:I would also suggest a larger diameter balance tube between the carbs. Hal can take care of that for you too. Pretty simple, quick, and inexpensive. It will let you comfortably reduce the idle, making your landings shorter without such aggressive breaking and shutdowns less violent. My static idle now is around 1000rpm.
This makes lots of sense to me actually. In LSRM school we had to synchronize at 2100-2200 RPM in order to get them to idle smooth even at 1400RPM. If we balanced at 1400RPM we get the shakes at cruise speeds. It was obvious something wasn't right.
Mister701 offline
Aircraft: Rans S7LS
Since I started this year's ski flying 2 days ago, (5 hours so far) I noticed a big advantage of the large cross over tube: when I do my runup and taxi to the start of my ramp, and then transition to skis, the low idle now attainable means I don't start creeping forward before the skis are fully transitioned.
Not sure about fitting the Warp hub, doesn't matter as they come with hardware and the hub.
PM'd you 701
Well, here's my airplane sitting in my hangar. I had my first hour today in gusty bumpy conditions. The bloke in the picture is Reggie Paulk from Winter Park Colorado. He's got a S7LS two serial numbers away from mine. The insurance company insisted that I have it flown home by a CFI with 25 make and model. I told them the son of a bitch didn't exist but I finally found one. He's a good guy. I'm an airplane owner again. It's a cool little beast but does not fly like a Mooney in heavy chop that's for sure. I'm happy. Dig them big tires man! Trent Palmer, eat your heart out.
Mister701 offline
Aircraft: Rans S7LS
Glad you got it home. Looks great.
gbflyer offline
gbflyer wrote:Glad you got it home. Looks great.
Boy what an ordeal. I closed on it Feb. 12 and got it home April 17. I flew it last evening at Stead then this morning we flew a few circuits at Stead then took off for Nervino where the wind was more up and down the runway and finished up my check out. The main runway at Stead (8/26) is closed until September for re-surfacing.
Mister701 offline
Aircraft: Rans S7LS
Awesome! Good things come to those who wait! Glad it all worked out, can't wait to see it.
CFOT offline
About time! Good deal, you'll like it.
Users browsing this forum: No registered users and 22 guests
