whee wrote:Can't tighten the wing fairing screws enough to keep them from coming loose, thus they have to be tightened before every flight.
For that, you could maybe back them out, gloop in a little silicone sealant, and tighten them up, so long as the screw is holding something. Once dry it'll hold the screw in until annual time when you pull it out, inspect everything, and redo it.
I'm screwing around back by the tail. I took the two fairings off and forgot which screw went in where, so some aren't grabbing anything, anymore. It's obnoxious when they're all different sizes, but when they're different pitches, too...
So I think I'm going to get an assortment of tinnermans and a tube of crazy glue, and experiment with bending the tins to fit and keep from turning, and then gluing them in place. I suspect it won't go exactly as planned. You're right that some of the places will be downright hard to do this with.
My mechanic's an old aluminum guy, he'll probably have a better idea.
