SCS Featherweight carpet
Anyone tried them?. Astounding weight reduction it seems with a clear warning of not being as durable as other options. Might have to apply ensolite foam too beneath it and that would double the weight but it'd still be very very light.
Canalguna offline
60
- Aircraft: TU206G Amphibian
Not sure about that particular product, but I have been using a carpet called "Flyweight" from Douglas Interiors. They supply commercial aircraft interior products. I have used in in a few of my aircraft and the product is defiantly durable. By weight, it was 62% lighter than the material I removed (actually weighed it). It is extremely durable, a bit higher priced than normal carpet. It is very tough to cut and is aircraft certified and comes with burn certs. Not a gigantic selection of colors, but I suspect your not decorating the Playboy Jet.
dogpilot offline
- Took ball and went home
902
- Aircraft: Cessna 206H Amphib, Caravan 675 Amphib
I recently recieved samples from SCS. The carpet is rediculously light weight! It states 9.6 ounces for a 12"x72" piece! Cost is $12 for that size. Their Ensolite is 14 ounces but the size is smaller at 12"x54" Still, very light stuff. I ordered 4-colored samplaes (4" dia.) and the Ensolite sample, You can barely feel the wieght of all of the samples in your hand. I'm figuring out the lightest possible interior on a plane I am nearly finished with. Unfortunately, if I go with the Oregon Aero Seats, I will be adding weight.
2036
- Aircraft: RANS S-7
