jlacharite wrote:... I have been searching around a bit to try and find a source for the 1/4" Selkirk foam to finish off the interior, but I can't seem to find it anywhere. Anybody know who currently sells it and where to buy it? Thanks!
Perfect, thanks! Didnt see it on their website, but that makes sense.bart wrote:jlacharite wrote:... I have been searching around a bit to try and find a source for the 1/4" Selkirk foam to finish off the interior, but I can't seem to find it anywhere. Anybody know who currently sells it and where to buy it? Thanks!
Just call Selkirk and order some direct. They cut it from a roll thats about 54 inches wide, and you tell them how many linear feet you need. 1/4" or 1/2" thickness.
Derail away! I guess now that I know where to get the foam, I'll need to know how to attach it or remove it as needed...asa wrote:Sounds like you got your answer so hopefully you don't mind if I derail this a bit..
In response to people using adhesive to stick the foam on, or contact cement, has anyone had to go through removing the stuff? Does it tear up the paint that you all worked so hard on or is the adhesive the weak link, or does the foam just turn to shreds? Has anyone done other methods of attaching it that are more removable?
Thanks
flyingzebra wrote:I originally used the recommended 3M spray adhesive but when July hit I ended up with a bunch of sagging
There was some corrosion under the adhesive that I stripped off on my 206. It was nice to be able to clean it off and stop it from continuing. I would have never seen it if it weren't for removing the black adhesive.akgreg wrote:I can’t understand why everyone is so set on using uber adhesives to attach foam. I have the self adhesive foam from spruce and it stuck just fine. I wiped everything down with denatured alcohol before attaching. Nothing moves. I didn’t strip any of old adhesive. Why take it off if it’s just getting covered with the foam. Seems like wasted time. I covered the foam with fabric using 3M 77 Spray Adhesive. Worked great.
akgreg wrote:Well, I guess everyone should start tearing out their interiors so they can remove all the adhesive and look for corrosion.
I never said that. But since I was so close anyway it was worth it for me. Would the skin have lasted another 40 years? Probably. Do I feel better that I took care of it in the plane that I am hauling my friends and family in? Yup.akgreg wrote:Well, I guess everyone should start tearing out their interiors so they can remove all the adhesive and look for corrosion.
