My manual is at the hangar as well. I will get back to you on specific numbers, but my recollection is that they had a speed associated with obstacle clearance (Vx) and one for max performance climb (Vy).
The following isn't meant to be anything other than a response to your question regarding what I use for speeds on a similarly equipped plane. Kevin and Rob can both fly circles around me. I am by no means an expert Skywagon pilot. The most important thing I think anyone can do when starting out is to learn a safe technique, know their limits with it, then keep experimenting in very small incremements to find what works best for you. With practice and an airfield you can put cones out on, or use the center stripe length with Google maps, you can start working toward optimizing your skills. I still want to get to a point where I can land consistently within the proverbial football field, but I am still a bit outside those limits with zero wind.
My bird's airspeed is in knots, but it is typically off the ground for good at 50 kts tail low with 20 deg flaps on T/O. If it is really gusty and length isn't an issue I will typically roll it a little more nose down and she will fly off at 60 knots indicated. I always use flaps 20 on takeoff, and drop them when it feels good. The flaps do limit max performance climb. Once cleaned up she climbs well at 80 - 85 Kts with not much loss on the VSI and not a crazy deck angle that something closer to Vy delivers.
For landing, I typically wheel land at 30 deg flaps if length or xwinds aren't in play, with three pulls on the trim wheel from full nose up. 60 kts down final, 55 over fence, and touch around 50 seems to give me the most consistent success. For short work I use 40 deg flap and reduce everything by 5 Kts. It requires a higher power setting, and is essentially how I was taught to 3 point, only instead of fully stalling it push it over on the mains and pulling the power right before the tailwheel hits, killing the lift. When it works, it works great. If it is gusty/thermally, or the timing is off, it can be an abrupt arrival. For really gusty or crosswind days, I go flaps 20 and use my wheel landing pattern speeds, plus a couple knots but no more than 5.
Not sure if this is helpful, but I will get some book numbers for you if you still need them.
Flynengr
