SkyCharts
I've been using skycharts pro for about 3 years and love it. Works well if you're only looking to replace paper charts, definitely not a replacement for apps like foreflight or wingx. Pay once for the app and the charts update with every cycle with no subscription fee.
Vick offline
823
- FindMeSpot URL: http://share.findmespot.com/shared/face ... WUk8CX06AP
Solum Volamus
Mon Sep 16, 2013 10:31 am
Vick wrote:I've been using skycharts pro for about 3 years and love it. Works well if you're only looking to replace paper charts, definitely not a replacement for apps like foreflight or wingx. Pay once for the app and the charts update with every cycle with no subscription fee.
1) Do they track you like foreflight?
2) I've heard they cover Mesico? Is that true?
Glidergeek offline
1937
- Aircraft: 1968 P206C
DG 400
Mon Sep 16, 2013 11:00 am
Only thing I have used them for is special use airspace. They seem the only source for that.
dogpilot offline
- Took ball and went home
902
- Aircraft: Cessna 206H Amphib, Caravan 675 Amphib
Mon Sep 16, 2013 11:33 am
dogpilot wrote:Only thing I have used them for is special use airspace. They seem the only source for that.
IE?
Glidergeek offline
1937
DG 400
Mon Sep 16, 2013 12:21 pm
Glidergeek wrote:2) I've heard they cover Mesico? Is that true?
You got me all excited, but I don't see anything suggesting that's the case. I use
http://www.dixdouze.com/xample/index.php/airnavigation for ipad charts in Mexico. Be aware that the charts are *very* old and untrustworthy on their own. However, the geolocation data is current and overlays on the charts. As an example of what you end up seeing; the airport near my office was shut down because the city was growing rapidly so the government did the standard "shut down the airport that used to be on the edge of the city and build a new one further out" thing. If you look at the charts in airnavpro you will see the old airport at the old location but also a computer generated icon for the new airport at the new location. For airports that haven't moved the generated icon overlays the one printed on the chart.
It's not a perfect system, but it's the best I've found so far.
rw2 offline
1799
- FindMeSpot URL: https://share.delorme.com/LaNaranjaDanzante
- Aircraft: Experimental Maule
An example of Special Use would be the Grand Canyon, nothing nefarious.
dogpilot offline
902
Glidergeek wrote:1) Do they track you like foreflight?
There is an aircraft icon that shows your position and follows in real time. There's also a rudimentary flight planner that works well enough. When you have a data signal it also overlays TAF/METAR/TFRs etc.
Like I said, it's not foreflight but as an alternative to buying paper charts it's a win at very reasonable cost.
Vick offline
823
Solum Volamus
