Finally got around to installing the Desser 31s on the Skywagon... it wasn't exactly a cake walk. Check it out:
mtv wrote:Easy way to check toe in/out is to use a laser pointer against a wall.
Gunny wrote:mtv wrote:Easy way to check toe in/out is to use a laser pointer against a wall.
Interesting. the way you do it with a Stearman is to run string lines down the center line of the airplane, then string lines from the center of each tire. That seems to work well. From my experience grease plates are only so..so...
gunny
mtv wrote:...I wouldn't try to set alignment without grease plates. It's really the only way to prevent friction from entering the equation.
It can be done without them, but it's hit and miss. If you're lucky, it'll be a hit.
In my experience, everyone hates grease plates. They're messy, and a PITA to clean up. But, they're the one sure way to get the gear where you want it....
I have plates inside an aviall parts bag. They stay greased and the grease stays in the bag. Very easy to use, easy to clean up, not messy. Works great for me.hotrod180 wrote:mtv wrote:...I wouldn't try to set alignment without grease plates. It's really the only way to prevent friction from entering the equation.
I've heard of using a plastic garbage bag instead of greased plates,
the two layers of plastic slip'n'slide pretty good.
Maybe not quite as good as greased plates,
but easier to deal with.
CFOT wrote:Looks great Gunny!
I have found that an engine hoist works great in situations where you don't have enough jack to do the job. I got myself into a particularly nasty patch of goat head thorns a while back, and had the forethought to block my axles when I put the airplane away after landing with one tire going flat. I showed up to the hangar in the morning to find both tires flat with the lower gear sitting on the blocks. Thought I was pretty clever until I realized there was no place to put the jack. The engine hoist worked great.
daedaluscan wrote:…..Just don't get excited to put the wheels back on when you have just painted the gear legs and the clear coat is still soft. Guess how I now know this.
asa wrote:Any reason not to use the floor jack from the get-go in place of the bottle jack?
daedaluscan wrote:
I use an engine hoist and a webbing strap wrapped around the gear.
