shorton wrote:Would a well documented small shop overhaul or field overhaul be a problem to you. Would it be substantially of less value than a big shop or factory overhaul as long as it is done to the same standards?
G44 wrote:Curious who that was Mike. I had a “small shop/local guy” overhaul in one of my 185’s, incredible engine! Local Anchorage guy. If I remember correctly his name is Werner Reimer.
Back to the OP question, the best overhaul in my opinion is a small shop somewhere, finding that shop and convincing a buyer is the challenge. Name overhauls may be better from a resale standpoint.
hotrod180 wrote:When times comes for me to have my 470 overhauled,
I plan on having an engine specialty shop do it.
IMHO it makes sense to have someone do it who does several engines a month,
as opposed to someone who does maybe one or two a year.
In my experience, the small GA shop guy is also more likely to have interruptions & distractions,
with people coming in needing flat tires fixed, oleos pumped up, etc.
mtv wrote:hotrod180 wrote:When times comes for me to have my 470 overhauled,
I plan on having an engine specialty shop do it.......
Yep, hire those unlicensed, barely trained dudes to assemble your engine, rather than that one licensed and experienced guy who takes pride in his or her engines,......
hotrod180 wrote:mtv wrote:hotrod180 wrote:When times comes for me to have my 470 overhauled,
1) Without knowing which "engine specialty shop" I might be referring to, (not the Continental factory BTW),
you're making a big assumption that it will be "unlicensed barely trained dudes" working on it.
It just might happen to be a one-man shop.
2) If you expect to have others respect your comments & opinions, you should reciprocate.
IMHO leading off with a simple "I disagree" followed by why is a more appropriate response than sarcasm.
G44 wrote:A couple of mechanics I know who build engines say they lock the shop door while building and follow a strict check list to eliminate distractions and miss items. Seems like a great way to operate!
hardtailjohn wrote:.... I know when I worked in the overhaul shop, we got a lot sharper on specific engines by doing a bunch of them,
specializing. ..... I do know, out of about 10 mechanics, there were only 3 of us with licenses, but there were some that had been doing overhauls for a lot of years that had no license, and I learned a LOT from them!!!!
