Need an estimate of how many hours to install.
How many knots do you really gain?
Mudwagon wrote:Need an estimate of how many hours to install.
Can you control the strobe separate from the position lights?
You can. Per the installation manual, there are 4 wires; you can wire the Flashing and Position lights to separate switches. The other 2 wires are ground.
I have 2 wires going to the nav lights on my cessna-172m. Can I wire the strobe and nav together and use the existing navswitch to run both nav and strobe continuously so I don't have to run 2 more wires and another switch? aircraft is VFR only. Thank You. RE: Orion 650
Per the supplier: I would not recommend this setup but it can be used that way. It is recommended that they use two separate power wires so they can operate the functions independently.
Are these legal for installation on a certified aircraft?
Yes, the Whelen Orion 650 series is FAA TSO approved for installation in certified aircraft.
Does the Orion 650 require a tail position light?
Per Whelen, the Orion 650 does not require the aircraft to have a tail light, but can if they choose. The unit has LED's on the back half of the unit to provide 180 degrees of strobe when mounted on the wing tip.
Does Whelen FAA Approval for installing the ORION 650 series on Certified Aircraft?
Does the Whelen Orion 650 Series Lighting have a Rear Position White Light separate from the strobe for use on aircraft that have no rear position light mounted on the tail?
No, this light does not have the rear position light. Take a look at P/N# 11-11365 or in other words the Orion 600 Series. This light would have the rear position light.
I currently have nav/whelen strobe wingtip lights on my 206. Can I use the wires from the strobe (after removing the power supply) for the strobe on the Orion 650 and the wires for the nav for the nav? In other words, will I have to run new wires?
You can use the existing wiring, the Orions just bypass the strobe power supply. No need to run new wiring.
SportsmanSTOL wrote:The Orion 650's are $500/ea. You would be looking at around $1000 pair for Whelen or $1195 for Aeroleds.
hotrod180 wrote:Get a smooth Stene's fin cap, then buy one of these and mount it on the fuselage.
http://www.aircraftspruce.com/catalog/e ... selage.php
Not as visible as fin-top or wingtip strobes, but cheap at $182, quick and easy to install.
Plenty good enough for my flying, which is 99% day VFR.
My C150TD had an aftermarket fin cap with one of these mounted on it, low profile and very clean looking.
I wish I could remember / figure out who manufactured it.
FWIW at night they're very effective, but IMHO strobes don't do much for you in the daytime.
