Backcountry Pilot • Sometimes, Two Horsepower is All You Need
21 posts • Page 1 of 2 • 1, 2
A friend of mine, Rod Snyder, took this picture in the early 70's. Let's see if you sharp eyed Backcountry types can tell where this was taken. No fair looking in the NTSB data base, it is there. We all should beware of the cause, summer is just around the corner.
robertc offline
Re: Sometimes, Two Horsepower is All You Need
Shaffer Meadows or Spotted Bear are my guesses.
Hammer offline
I am guessing Schafer Meadows.
Good reminder that the warm weather is coming and our machines don't perform as we are accustomed to when it's cool.
Scolopax offline
I don't think the mountains around Schafer or Spotted Bear look like the ones in the photo. Could be wrong though.
SamIntel offline
Aircraft: Cessna 140
All I know is that riding a horse up the river like that looks quite pleasant.
Not surprised to see yet another V-tail go down in a density altitude take-off. (I assume take off) Used to get them quite often at South Tahoe - Truckee - etc [-X
Never been in what looks like a "lower" section of the SALMON <edit> that late in the year. (colors)
Never flown that low nor in that direction. (view looks to be upstream with my fuzzy old vision)
Will try to use some terrain clues, and some old down stream approach memories, to possibly reconstruct the approach to a nearby strip. [-o< [-o< (Not the one I am assuming the Bo took off from)
Damn - how do I get back to the picture without losing this?
The dark ridge of trees on the left looks familiar. Take off left to right. (I hope) [-o<
There may be a slab of slate on the opposite side of the river and just upstream from the above mentioned tree line.
As I recall there are two "usual" ridges that rise up on the right side of the river which are used as turn around spots. One is a shorter approach and the other drops you down over Buckskin Bills place.
On the return to land you get over to and stay on the left side of the river, (right side in photo) and look for a certain set of rapids immediately beyond the quick decision turn into Wilson Bar.
Been fun - even if I missed.
Am I even close? [-o<
Trim
Trimtab offline
Trimtab
It can be true, even if it didn't happen - Ken Keasey - mostly*
Man invented language so he could hide the truth from others - Tallyrand - sort of
Zzz wrote:All I know is that riding a horse up the river like that looks quite pleasant.
You've never owned horses have you? :D
Jeredp offline
Aircraft: Cessna 172
[emoji106]
gbflyer offline
Trimtab wrote:Not surprised to see yet another V-tail go down in a density altitude take-off. (I assume take off) Used to get them quite often at South Tahoe - Truckee - etc [-X
Never been in what looks like a "lower" section of the Snake that late in the year. (colors)
Trim
Go west
robertc offline
So what do I know? Even had the wrong river! Edited it though.
Trimtab offline
Trimtab
My first job as a kid was cleaning horse stalls. That's as close as I've gotten and is probably the reason I've avoided them since.
We had a horse when I was a kid. The only way we could afford to stable it was by mucking all the stalls in the barn once a week. I liked that horse, but that was hard work. The kind of work you sign your kid up for when they're young to "build character." wait...
You know, the older I get the smarter my parents get.
RobertC
Do I sense a thread crash? :evil:
Maybe all the Idaho flyers have flown the coop to Kalif. :shock:
Gonna go find a boot scraper. :mrgreen:
Trimmed for flack.
Trimtab offline
Trimtab
Trimtab wrote:RobertC
Trimmed for flack.
All the equine talk is sort of apt to the original question...figured out where it is.
Hammer offline
Trimmed for flack.
Must have something to do with a horse ranch.
robertc offline
It might buff out
3-4054 74/10/10 LAGRANDE,OREG BEECH E35 CR- 0 0 1 NONCOMMERCIAL PRIVATE, AGE 50, 1008
TIME - 0830 N3212C PX- 0 0 2 PLEASURE/PERSONAL TRANSP TOTAL HOURS, 995 IN TYPE,
DAMAGE-SUBSTANTIAL OT- 0 0 0 NOT INSTRUMENT RATED.
NAME OF AIRPORT - REDS HORSE RANCH
DEPARTURE POINT INTENDED DESTINATION
LAGRANDE,OREG LOCAL
TYPE OF ACCIDENT PHASE OF OPERATION
STALL: MUSH TAKEOFF: ABORTED
PROBABLE CAUSE(S)
PILOT IN COMMAND - INADEQUATE PREFLIGHT PREPARATION AND/OR PLANNING
PILOT IN COMMAND - PREMATURE LIFT-OFF
PILOT IN COMMAND - FAILED TO OBTAIN/MAINTAIN FLYING SPEED
FACTOR(S)
WEATHER - HIGH DENSITY ALTITUDE
TERRAIN - HIGH OBSTRUCTIONS
MISCELLANEOUS ACTS,CONDITIONS - AIRCRAFT CAME TO REST IN WATER
WEATHER BRIEFING - NO RECORD OF BRIEFING RECEIVED
WEATHER FORECAST - FORECAST SUBSTANTIALLY CORRECT
SKY CONDITION CEILING AT ACCIDENT SITE
CLEAR UNLIMITED
VISIBILITY AT ACCIDENT SITE PRECIPITATION AT ACCIDENT SITE
5 OR OVER(UNLIMITED) NONE
OBSTRUCTIONS TO VISION AT ACCIDENT SITE TEMPERATURE-F
NONE 60
TYPE OF WEATHER CONDITIONS TYPE OF FLIGHT PLAN
VFR NONE
REMARKS- UNABLE TO CLR OBSTRUCTIONS.SETTLED BACK TO RWY.RAN OFF END INTO MINAM RIVER.
But, not to be outdone, we have this one too at the same strip. Apparently this is an aircraft eating river. Reading both accounts gives a cautionary tale for summer flying.
3-2264 71/6/30 LOSTINE,OREG CESSNA 172F CR- 0 0 1 NONCOMMERCIAL COMMERCIAL, AGE 29, 165
TIME - 1600 N8303U PX- 0 0 2 PLEASURE/PERSONAL TRANSP TOTAL HOURS, 16 IN TYPE,
DAMAGE-DESTROYED OT- 0 0 0 NOT INSTRUMENT RATED.
NAME OF AIRPORT - RED HORSE RANCH
LOSTINE,OREG PASCO,WASH
COLLIDED WITH: FENCE,FENCEPOSTS TAKEOFF: INITIAL CLIMB
NOSE OVER/DOWN TAKEOFF: INITIAL CLIMB
PROBABLE CAUSE(S)
PILOT IN COMMAND - EXERCISED POOR JUDGMENT
FACTOR(S)
AIRPORTS/AIRWAYS/FACILITIES - AIRPORT CONDITIONS: WET RUNWAY
AIRPORTS/AIRWAYS/FACILITIES - AIRPORT CONDITIONS: SOFT RUNWAY
WEATHER - HIGH TEMPERATURE
MISCELLANEOUS ACTS,CONDITIONS - DOWNWIND
CLEAR UNLIMITED
OBSTRUCTIONS TO VISION AT ACCIDENT SITE WIND DIRECTION-DEGREES
NONE 160
WIND VELOCITY-KNOTS TYPE OF WEATHER CONDITIONS
15 VFR
TYPE OF FLIGHT PLAN
NONE
REMARKS- ATMPTD TKOF W GUSTING DNWND,HIGH TEMP,HIGH DENSTY ALT.CRASHED ON 3D TKOF ATMT. ONE WAY STRIP.
Photos-Rod Snyder
robertc offline
You know what else they rode up that river? A Caterpillar D8 with a snorkel kit on it, or so the story goes. It's how they graded those strips.
I surrender - I have never taken off from Makay Bar and was trying to picture the country in reverse.
Also never been to the other two strips.
Remember reading about several trips going into Reds and or Minam.. Think I read one is closed?!?
Seems if ya missed the first on you could skip over a fence into the next one or something like that.
Thanks again Robert
Maybe you have another or two.
Trimtab offline
Trimtab
I think I've cleaned one or two..... :wink: It's good work and a good way to get your mind off the BS going on in the world!
hardtailjohn offline
The first time I went into that strip I was right seat in a straight tail 182. We had come over the top from Baker City and followed the Minam downriver and set up on a left downwind. Being in the right seat I didn't get a good look at the strip until we were coming out of base to final. I remember thinking we were pretty high, and kept waiting for my buddy to throw in an aggressive slip or something. Looking up the canyon I was not too excited about the prospect of going around.
As much as I tried to keep my mouth shut and let him concentrate, I couldn't stand it any more as we passed completely over the strip and continued out to the river bend below tree top level. That's where I let loose with a "WTF are you doing!!?" :shock: [-o<
About that time the nice long strip at Red's came in to view. I hadn't realized there were two strips :oops: ...what a pretty sight! =D>
CFOT offline
