Backcountry Pilot • SPOT HUG - Anti Theft
5 postsPage 1 of 1
I see SPOT just a new device for Marine Anti-Theft & Detection. I suppose this could be used on any vehicle, though.
http://www.findmespot.com/en/pressroom/
blackrock offline
Aircraft: Bearhawk
Re: SPOT HUG - Anti Theft
"UNAUTHORIZED MOVEMENT NOTIFICATION
By establishing a virtual security perimeter around your boat, SPOT HUG detects Unauthorized Movement when your boat moves more than 500 meters without your authority and the key FOB is not present. A notification with the GPS position is automatically sent to the Asset Monitoring Center who alert local authorities (where available)."
This does not seem to be an anit-theft device, more of an alert system. In my case, when my plane moved more than 500 meters it was in the air and going someplace unknown without me!! Now, if the device could track the vehicle and enable lawenforcement to arrest the pricks and return the plane, that would be worthwhile.
FloatFlyer offline
FloatFlyer wrote:In my case, when my plane moved more than 500 meters it was in the air and going someplace unknown without me!! .
Now there's a good story worth a post... go on with the details on how you had your bird fly on its own!
Backcountry Tundra offline
FloatFlyer wrote:"UNAUTHORIZED MOVEMENT NOTIFICATION
It sounds like it at least sends a daily location, provded the crooks don't disable it first.
100% satellite-based for maximum coverage
Unauthorized Movement alert notification to Asset Monitoring Center
Receive Daily Status update message with boat's location and any sensor notifications
Sensor Alert monitoring and notification for bilge, engine and battery monitoring. Configure up to 4 monitoring sensors
Key FOB for easy wireless activation
Wireless Keypad security and messaging system
Uses battery power or direct line power
Easy to install
X2 on the where did my plane go story!!! WTF happened?
blackrock offline
Aircraft: Bearhawk
Old one, but seems appropriate :D
L-19 offline
5 postsPage 1 of 1
