highroad wrote:How long will my shared spot page show todays trip? Is it just 24 hrs?
Also, those of you running 8.50's. What air pressure do you run in the mains and the Tail Wheel? I have been running just under 25psi and would like to go lower if it will make a difference in the rocks.
Thanks again for all of the help with the spot tracking,
Brent
I run 15psi in my 8.50's and it works fine. Might want to go a bit more if your heavy. 25psi sounds a bit to much though.
Tailwheel tire, just so its good and firm. Don't know that I ever gauged it.
As far as making a difference on the rocks. Lower pressure will stop you alot shorter. But also requires more room to take off. Absorbs the rock impact better to. Just be careful landing on pavement with low tire pressure. I've never had my plane on pavement, but I'll bet it's squirrely.
