Really raunchy air today, but what the hell.
https://vimeo.com/149583657
Battson wrote:Looks good, you can definitely see the shocks going to work.
It's interesting how much harder the shocks work on the full stop landing, when you put all the weight on them. On the fly-bys the look like they aren't doing as much work, while the wing is still lifting the plane most of the time.
Barnstormer wrote:I don't think I posted the first test flight I did with the TK 1's with the smaller shocks (maybe over in mods I did). Nor did I do any kind of write up, so here goes:
The difference between the TK 1 system and the AOSS is immediately noticeable from the moment you start moving the airplane. There is a slight compression of the shocks in turns that is a bit unsettling at first, but if you watch the end of my first video (below) you’ll see me doing high speed ’S’ turns without excessive wing dip. The same holds true on side hills, the downhill suspension will compress some allowing the wing to dip, but not to the point of concern.
Certainly takeoffs from rough terrain will feel smoother, but the real amazement occurs during the first landing. It will feel “pillow soft”, so much so that you won’t believe it, so you’ll do it again and again. And if you are like me you’ll start trying rougher and rougher landings and be astonished at how soft they feel. Equally important is the rebound is metered so at worse the plane will momentarily bounce an inch or so back into the air, but usually you’ll just “stick” the landing (watch the drop in at the end of the first video).
If you continue to push the landing envelope you’ll soon realize that the tailwheel suspension is now the weak link. The mains will never again feel rough, so you’ll land stuff that the tailwheel now complains about. Hence the reason I have Dan’s new T3 tail wheel system arriving Tuesday.
The whole initial experience reminds me of the first time I drove a Ford Raptor. After a bunch of King Ranch’s the Raptor’s suspension felt mushy, almost “Cadillac” like. I didn’t fully appreciate it until I put it through the paces at high speed on rough terrain. There’s not another pickup truck made that could even come close to approaching the speed at which the Raptor can handle rough terrain, and if it tried it’d soon leave parts scattered everywhere while the Raptor took it in stride.
That’s what the TK 1 Racing suspension does compared to the AOSS.
If you’ll watch this first video below, at the end you’ll see me drop it from about four feet after hanging the nose high SQ2 style. You can hear the suspension barely bottom out, but even so the hit was softer then with my AOSS suspension, and I didn’t bounce back in the air. Initially I had the smaller shocks which didn’t have enough capacity to adequately support a loaded-up SQ2. TK 1 sent me slightly larger replacement shocks which are what I’m testing in the second video above. I’ve got a 100psi less pressure in them and am not bottoming out.
https://vimeo.com/144569279
fiftynineSC wrote:Great stuff. My plane has little tires, but I'd love to come out there and hit what I can with you guys one of these days. I generally make it to Fredericksburg for breakfast at least once a month.
Bill
Barnstormer wrote:fiftynineSC wrote:Great stuff. My plane has little tires, but I'd love to come out there and hit what I can with you guys one of these days. I generally make it to Fredericksburg for breakfast at least once a month.
Bill
About the only place that might work with small tires is the strip on the island, which is around 900' long. But before landing you'd want to drag it first to make sure it felt ok with your tire size.
You should definitely plan on coming over for the Texas STOL Roundup, we will do fly-outs Sunday morning including going to the island.
