Starter for O200 on Champ
Can someone please share the process of adding a push button starter to a Champ with an O200? Curious about cost of parts, labor and time.
Icarus747 offline
2
Are you converting from a pull starter, or does it not have a starter at all on it right now?
5186
Wed Jun 30, 2021 12:45 am
Amodel offline
20
- Aircraft: Cub
A1Skinner wrote:Are you converting from a pull starter, or does it not have a starter at all on it right now?
Fresh install. No electrics or pull starter.
Icarus747 offline
2
Keep in mind that if you install an alternator, you will be subject to requirements for ADS-B out and/or a transponder.
But you will still be exempt with a battery-only electrical system.
10534
