Backcountry Pilot • Static System rebuild - push on fittings
6 postsPage 1 of 1
Do any of you guys know of the legality of using these push on fittings for the static system in a Cessna? They seem to be all the rage in the experimental community versus using Nyloseal.
https://www.steinair.com/product-catego ... t_count=24
r0bst3r offline
Aircraft: C182A
Re: Static System rebuild - push on fittings
Those are all shark fittings. Amazing at your house you can connect copper to PVC and if the od is right they don't leak. I would be curious if they are legal for use in certified aircraft but I would wager no.
http://www.sharkbite.com/
r0bst3r wrote:Do any of you guys know of the legality of using these push on fittings for the static system in a Cessna? They seem to be all the rage in the experimental community versus using Nyloseal.
tbag offline
Aircraft: 1956 Piper Pacer
I’ve considered using those fittings from SteinAir. My radio man told me I could probably get away with it, but advised against it as he wants to do it right the first time.
pilotryan offline
Aircraft: C185 / C310R
Falcon 900B
Install the damn things. They are awesome. No one will get their panties in a ruffle. You can basically use whatever you want as long as the system will pass the proof test as stated in Sec.23.1325
akgreg offline
Aircraft: Yes
Agreed... my avionics shop didn't care as long as they didn't leak, and they don't.
akschu offline
Contributing author
Aircraft: 1949 C-170
20?? 4 place Bearhawk
When I replaced my entire pitot/static system a couple years ago I used all push in type fittings and nylon tubing throughout from stein air. Easy to work with, cut, route and install. I’d do it again in a heartbeat. I believe some new certified aircraft are coming from the factory this way.
Newbizor offline
6 postsPage 1 of 1
