Backcountry Pilot • STEC 50 AP Disconnect Switch Issue
4 postsPage 1 of 1
Good Day All,
The STEC 50 installed in an aircraft that i use works great. No issues at all......however....the owner had the the yoke mounted disconnect switch replaced only due to the fact that it was "sheared off" and wanted a new one put in. After the "test" function...as per normal..the "RDY" light is illuminated. Next, when you push the "on/off" button to engage the STB mode nothing happens. After playing with it for a minute or two...I realized that if i hold the A/P disconnect switch in, in the depressed position I can activate the "STB" mode. To put it simply...if I hold the A/P disconnect switch in..the unit works fine.
Any ideas..a simple or complex fix?
Cheers
macdon221
macdon221 offline
Macdon221
Re: STEC 50 AP Disconnect Switch Issue
They probably installed a "Push to Talk" type switch instead of an "On Off" switch.
I'll leave it to others to figure out how that might happen :)
SkyTruck offline
'80 A185F
Thanks SkyTruck....any other theories out there??
Macdon221
macdon221 offline
Macdon221
As I recall the push button only is used to complete a connection that holds a relay somewhere in the system on the altitude hold portion. As far as the nav portion I am not sure.all Cobham aka stec 1-817-215-7600 ask for tech support they can help.
bcdpilot offline
4 postsPage 1 of 1
