Steve, any progress on the 180hp Husky approvals?
G44 wrote:Steve, any progress on the 180hp Husky approvals?
CParker wrote:What's the advantage of ditching the remote cable system?
Yes you just reach up and use the same sump checker that you use for your tanks. Not really much of a reasch as the bottom of the drain is right there.CParker wrote:Without the cable, are you reaching up through the cowl flap and draining the bowl then? Sorry, unfamiliar.
I'm a little worried about my strainer drain, I have to pull pretty hard/far ton the knob to get any flow, to the point where I think the aluminum where the pull is mounted is starting to give a little from years of yanking.
Flying Dave wrote:G44 wrote:Steve, any progress on the 180hp Husky approvals?
It appears all Husky models are now on the list.
Edit: well maybe not the C 180.
Brian-StevesAircraft wrote:Flying Dave wrote:G44 wrote:Steve, any progress on the 180hp Husky approvals?
Still working on it.. Its FAA and Covid.. They work from home and are slower than slow..\
I have at least 6 or so models to add.
Brian
A1Skinner wrote:Yes you just reach up and use the same sump checker that you use for your tanks. Not really much of a reasch as the bottom of the drain is right there.CParker wrote:Without the cable, are you reaching up through the cowl flap and draining the bowl then? Sorry, unfamiliar.
Another advantage is the ease of servicing these compared to removing the old stand pipes on the original one. Steves are awesome.
