Backcountry Pilot • Stinson owners with PZL/Franklin 220hp engines
10 postsPage 1 of 1
I am in need of some STC supporting documents for the 6A-350-CR1 engine. All of my documents where lost in a vehicle break in. My engine was installed under the Seaplanes Inc. STC. According to the FAA I can use another airplane's STC paperwork as long as I have my form 337. If someone could get a message to mountainmike I would appreciate it.
Thanks
bluegrass aviator
bluegrassaviator offline
Re: Stinson owners with PZL/Franklin 220hp engines
Might want to order the CD for the plane from the FAA. That is what I did when documents were missing for a float installation on my Champ.
Other than that Rhyppa may chime in if he sees the thread. He had a Stinson with the 220 Franklin and may know its where abouts to try and help out with paperwork.
Good luck
I doon't think the FAA would have any of the "STC supporting documents" (blueprinnts, specs, etc), at least in the aircraft file-- they would just have the filed 337. Did you look up the Seaplanes Inc STC number? Maybe someone else owns it now and can help you out.
I think the Seaplanes STC's for Franklins is now owned by Franklin Aircraft Engines, Ft Collins, CO., 136 Racquette Dr., 80524
macktruckfarm offline
PM sent.
Tadpole has all the paperwork now, but I believe he can get you what you need.
MM
bluegrassaviator wrote:I am in need of some STC supporting documents for the 6A-350-CR1 engine.
Shoot me a PM with your email address and what' you're looking for. I have a 220hp 108-2.
Unfortunately the FAA will not release any information on STC's. I went around and around with them. Even though the Franklin Engine Comapny no longer exist(and the STC is basically in limbo) they will not release the STC Data. I have the data disc but it only shows 337's and not the POH supplement that's required for flight. I will keep a digital copy of all paper work from now on. I have however found a few 220 owners that are going to help me out. Thanks for the help.
bluegrassaviator
Seaplane Inc no longer exist. Their building burned years ago and the company split up.
I have a good friend who has a 220 F 108-3 and I may be able to get the docs from him as well.
I will have a try at it.
soaringhiggy offline
48 Stinson 108-3
I'll volunteer the IA/AP who did my install. He happens to be the proud owner now as well.if you haven't sorted this out yet, PM me and I'll give you his contact info.
Cheers,
Chaz
Chazdevil offline
10 postsPage 1 of 1
Users browsing this forum: No registered users and 19 guests
