There's a straight tail 172 with a 180hp engine and the tail wheel conversion which might be coming up for sale on my field.
Off hand I'm leery of tail wheel conversions, but I thought I'd see if anyone around here has flown one.
ravi wrote:There's a straight tail 172 with a 180hp engine and the tail wheel conversion which might be coming up for sale on my field.
GumpAir wrote: The C180 fixed that problem with the trimable stabilizer.
qmdv wrote:My 182 B has the trimable stabilizer and what a soft touch it has. When trimmed at low speed you just have to tickle the elevator a touch to get a responce.
The 180's and 185's used this tell the end of production.
The geometry is wrong, and as was discussed in a forum a few weeks ago, the fixed horizontal stab doesn't give enough elevator authority to flare while using full flaps. The C180 fixed that problem with the trimable stabilizer. Makes a huge difference.
ravi wrote:Maybe I'm comparing apples to pineapples, but since the 170 also lacks the trimable stabilizer, does it have the same issues? If not, what do you think the difference is...the geometry of the main landing gear or the actual tail surface?
ravi wrote:but try and pull it back to a full stall to three-point it with flaps out over 20 degrees, and you run out of ooomph in the elevator
I wonder if VG's would improve the elevator ooomph the same way they improve rudder authority on a twin?
a64pilot wrote:The VG's on the horizontal of the Maule help, but it's adding just a little bit of power at the bottom during rotation that does the trick. I'm not trying to turn this into a Maule discussion, but the handling sounds so similar, maybe the same trick would work.
aftCG wrote:
It seems like loading to a more rearward CG might otherwise be just enough.
ZK Kiwi wrote:...the C170C prototype,which was certified but never released, was converted to a 172 and sold according the Bill Thompson's book.
