This cost me a big fat zero. I made it full scale, based on the pic I printed out, having no idea if that was a full scale pic or not, it looks about right anyway, as you can see. My needs will put quite a bit less stress on it then towing sailplanes, so I re-engineered it downwards/made it lighter and wimpier. I will use it as I push my plane out the hangar, on it's wheels, and then transition to the skis, right at the last bit of level area outside my hangar, from there it's 14% down all the way. With this release, if I change my mind and decide I really don't want to go ski flying, I'll be able to abort. The way I've been doing it, once transitioned to the skis ( about 30 seconds to deploy them, engine off usually) and then once restarted, I'm going flying as soon as I restart, like it or not.
I have yet to figure out how to install it, my last thought today while still in the shop was: rather then screw with figuring out a mount on the plane, which would get complicated quick, I may just use the HydroSwing door lower truss as a hard point to rig to. I'd leave the entire release on the ground in other words, using it backwards in effect. This will require me to leave one door open to pull the release line, and a pully to release the direction of travel, I'll figure something out...even if it means I fly off with 20' of rope trailing behind me, it will still be simpler and lighter then installing the entire contraption onboard. My primary/only use of this will be at my home strip, In the past I have had a few times where I could have used a tail release while landing out somewhere, but I have ski flying all figured out now and those times are past
