contactflying wrote:Noticeable acceleration occurs when:
1. the nose or tail wheel is off the surface,
2. the mains are off the surface,
3. and the nose is pushed down to remain in low ground effect.
Big rocks, brakes, mud, high grass, tie downs, and drag chutes are serious limitations to acceleration, which is necessary for takeoff.
We want to go fast on takeoff and slow on landing.
contactflying wrote:M6RV6-That was a good one. If you can get the mains off sooner and then level in low ground effect, it helps. You are a bit tight there. Do what is comfortable. Is that engine a "shakin Jake?"
