Rob wrote:
Be careful what you wish for here... ...but light without consideration to CG is an exercise in futility... nose heavy when light to leave an acceptable CG envelope for heavy ops... cubs had to address this issue by adding weight....
Rob's absolutely correct of course. Making something lighter is
usually a good thing, but if it causes some other problem then it could become a can of worms. In terms of old traditional aircraft thinking, every pound you can take off the tail allows you to take three or four pounds off the nose. But that is
static thinking, based on the assumption that you can remove weight from wherever you have to in order to keep the CG where you want it. As Rob pointed out, that may not always be the case.
Regarding this specific idea of using a lighter tail spring, and then possibly needing to put tail weight back in to compensate for the increased nose-heaviness, there is still a potential benefit to be had. It might be possible to add that tail weight back in with something more useful than just dead weight.
One potentially smart move that you can make as an EXP builder is to build or outfit the airplane so that your emergency kit, your reserve water or MRE's, or your 500 rounds of survival ammunition, can be moved fore and aft quite some distance. Like a long ski tube, or a separate long ski tube in addition.
So when you are flying light or solo, and your airplane would otherwise be nose-heavy, you can balance the airplane using stuff you would already be carrying. Slide the ammo pack or whatever all the way aft in the tube, and you can fly at 75-85% of aft CG (or wherever your airplane flies best). When you load up the plane with the wife and in-laws, then you can move the emergency kit forward so your CG is still safe.
Or, when appropriate, you can REMOVE that 500 rounds of ammo, and save that extra five or ten pounds altogether.
But you might want to save just one of those rounds if it's a long flight with the in-laws
