Take Off Fuel Flow, O-470R
Hi,
How many seconds after reaching T/O MP do you get Max T/O FF on your carburated O-470 engine?
Mine, an O-470R,
JPI graph shows to have a FF of 9.3GPH when reaching T/O power at sea level, some 20 sec. later stabilized at 21 GPH
As you will see on the graph, EGT’s reach almost 1500F and then as FF increases drop some 70F.
CHT’s are below 350 during T/O and initial climb.
Would like to compare to other carburated O-470’s
Thx.
[email protected] offline
151
- Aircraft: Cessna 180 Skywagon
Interesting! I wonder if this has anything to do with the CS prop? I’d imagine it wouldn’t be that big of a difference if any though. Maybe latency in the gauge? Smoothing in the signal?
3705
- FindMeSpot URL: https://share.delorme.com/camtom12
- Aircraft: Ruppe Racer
Man that seems like a very long lag period for it to get to full flow. Granted I'm running a IO-520, but when I firewall it and look down a couple seconds later after I'm off the ground I'm getting 28ish, it's pretty immediate. The carb may take a bit longer, but 20 seconds is a long time...
5219
- Aircraft: Cessna 210J, Citabria 7GCBC, AT402/502/602
Sun Mar 06, 2022 10:24 am
I will check mine the next time I am up, I think that is a instrument lag issue. How fast does the fuel flow change when you are pulling power? DENNY
DENNY offline
791
DENNY
Thx for the interest.
The IO 520 graph coming also from a JPI and believe the same fuel flow sensor shows the MP and FF lines going up almost overlapping each other.
They reach their maximum at the same time and EGT's don't go up and then down like with the carburated 470.
Believe what we see on the graph for the 470 is quite true.
I would be very interested to compare, guess they will be similar but would really like to see how much.
Downloading the data and seeing these graphs takes seconds and its free.
Subscribe to Savvy Aviation.
Download your flights from your engine monitor to a memory stick.
Then drag the file to the box at Savvy and open it up.
As simple as that. All free.
151
I checked this morning and the O-470R in my carbureted ‘56 Skywagon peaks at between 22.5 and 23.1 GPH around 5 seconds after liftoff as measured by a JPI FS-450 fuel flow/totalizer gauge.
48RagwingPilot offline
140
Thx, any idea how long from full throttle in to lift off?
I envy your 23Gls/hr FF.
151
151
I would estimate 5-6 seconds from full throttle to liftoff. Cool air, slight headwind.
140
140
Makes me envy your carb. even more.
151
Mon Mar 07, 2022 12:38 pm
Have had the intention to see how it reacts going back on the throttle Denny but so far forgotten...
Thx for the comment.
151
