Backcountry Pilot • take-off with my stol kit
55 postsPage 3 of 31, 2, 3
Re: take-off with my stol kit
Once&future, the technique should work equally for trigears as for taildraggers.
First trick is to judge getting your tail as close to the fence as possible as you come around followed by full power at a point about 20deg from takeoff direction (varies with aircraft and thrust).
The idea is you already have overcome tyre/wheel rolling resistance plus start and acceleration of the 'mass' and the bonus is that the prop is being moved into undisturbed/clean air, rather than turbulant/dirty air as in holding brakes and releasing, plus as noted, no rock damage.
maules.com offline
Thanks, I use the rolling takeoff quite often but always to the left because with my bird using p-factor to get it around 180 degrees is advantageous. It makes sense that it would help straighten out the right turn, the harder part is beginning the right turn :) especially on packed snow and ice! I'll play with it both directions now that we are back to bare ground.
Judicious use of throttle until one is assured of making the beeline down the runway is advised :O
Wasted runway, Maule.com makes a good point. I saw two examples of it yesterday, not a shortfield situation but still bad technique. The first was a Beechjet that was 'position and hold" at least 1000 ft. down the runway. I have no idea what they were thinking. After he took off a G 4 lined up with about 250 feet of pavement behind them. On a 200 ft. wide runway there is no excuse for not being able to comfortably line up, without dragging the brakes, within 100 feet of the end of the pavement even in that class of airplane. ( I was next and used 23 ft..... :D )
porterjet offline
KSBP
Along with being sort of narrow and a little brushy, this spot is also kind of short. Will Crash make a J-turn here I wonder or power up with some brakes?
disclaimer: Pic borrowed from SC.org. Way above my pay grade. Yes, he lands there on purpose.:D
gbflyer offline
mtv wrote:......A Cessna 170 need not be a lame steering machine. Mine steers at least as well as ANY 180 or Cub, and better than most. I worked to modify the steering to improve. This was field approved out of the FAI office. It's pretty much a no brainer. Get in touch if you want more info. IT's not hard, and makes a world of difference. ...
I'd like to hear more about this. How about starting a new post to explain/discuss the mod?
Eric
I'll post a picture. First, I'll have to TAKE one, of course. Might be a day or two.
And, that runway that Crash's airplane is on in the weeds is plenty long enough to leave without holding the brakes.
If you like your prop (and it's hard not to at the current price of props) DO NOT hold the brakes on stuff like this, and run up to full power.
I have a Warrior with Horton wing tips and gap seals - I haven’t tested against POH/AFM but don’t think it shortens take off dramatically. It does however deliver 120KTAS.
It earns its keep at a flying club.
In comparing book performance I was intrigued that a 1955 Cessna 170B POH has a take off distance required of 1625 feet (2200 lbs ISA Sea Level No wind).
The prosaic taper wing Warrior shows 1500 feet similar conditions (2325 lbs).
L18C-95 offline
Aircraft: Piper L18C-95
GumpAir wrote:
raccoon62 wrote:...any thoughts on angle of attack indicators?
Spend your money on gas instead, and learn how to read AOA, lift, and weight transfer through the seat of your pants.
Another vote for this answer.
A old mentor of mine, he got an AOA thingy on his cub...regretted it, never really uses it, because he's "too busy flying the airplane to look at the gauges"...that butt feel, it's kinda hard to grasp or understand before you get it. I definitely struggled for a long time with it, and am still learning, but it makes sense now and I can do it....so when you're trying to figure it out, don't worry if it's kinda confusing or doesn't make much sense!!
When I'm doing short field ops, I'll steal a one or two quick glances at specific moments...one, at my airspeed about 1/4 to 1/3 of the way down my takeoff roll. That's when I'm making a go/abort decision. The other, when I'm on short final...I have a specific speed I'm looking for, I make sure I've got that speed as a reference point, then from there I just slow down by feel until touchdown.
All that is to say, money spent on avgas is money well spent :)
dpadvo offline
Love that touchy feely stuff!
But the Cessna POH says to hold the brakes and throttle up to full power for a short field take off. Are you guys saying that Cessna is wrong? How can this be? :lol:
topgun260 offline
MTV is RIGHT ON.
racoon62 you definitely need to get with a competent short field/soft field instructor. Not some instructor whose never been off the pavement. And please do so before you hurt yourself or someone else.
Oh and welcome. :-)
mtv wrote:Let me try this in a little more "politically correct"manner--something I'm not always good at:
Go find an experienced instructor. By that, I mean someone who's worked airplanes in confined areas. Someone who has experience with those modifications and your airplane type would also be in order.
I can tell you that holding full nose up elevator till the airplane lifts off is NOT the best STOL approach for a C-172 with those mods, and yes, I've flown that kind of setup. The Sportsman cuff does not like really high deck angles. It won't do anything ugly at very high deck angles, but it won't lift as well, which is what you need it to do. It works largely because it adds a lot of wing area (and the camber changes,of course). Note that I'm talking DECK ANGLE here, not alpha.
If you're banging the tail, there are a couple issues: First, it is entirely possible to damage the tail doing this. It is also possible to jam some things in the tail, causing control problems--not good. Finally, doing so puts the wing at such a high angle of attack that I'm betting it's well above critical AOA while on the ground. Now, you're rolling along, eating up runway, while the wing makes all sorts of aerodynamic drag and darn little lift. Again, not good. Especially on a short runway.
Now, as to whether you should stop, apply brakes, then full power, etc, or do a rolling takeoff: I would almost (always gotta have those weasel words) NEVER stop on an off airport unprepared surface then use full power with brakes applied, due to the potential for prop damage. Even if you have a very narrow strip, and turning around is a bit tight, you still have to turn around and face the takeoff run.
Unless you are turning around, then shutting down, and pushing the airplane BACK further to give you more takeoff area (which would be a holy crap kinda deal) you will still benefit from keeping it rolling as you complete the turn, accelerating away. As Tim said, even if you start the takeoff with 2 kt forward speed, that's 2 kts you don't have to accelerate to. Get the thing configured for takeoff as you back taxi, and as you near completion of your turn to the takeoff heading, come in smoothly with full power and STAY OFF THE BRAKES. It is REALLY easy in these airplanes to ride the brakes a bit without really realizing it. Keep your feet flat on the floor once you start the t/o run, with just the tips of your toes on the bottom of the rudder pedals. I think you'll find that your performance will be better, and you'll really be doing your prop a favor.
Now, as to getting used to the Sportsman/VG combo--I really, really, really strongly suggest getting some dual instruction with someone who has experience there.
Test pilots generally get paid a LOT more money that most of us do. There's a reason for that.
Barnstormer offline
9 year old post? Holy Thread Resurrection Batman![emoji1]
gbflyer offline
mtv wrote:Holy shit!! Find a qualified instructor and learn to fly.
LOL!!
gbflyer wrote:9 year old post? Holy Thread Resurrection Batman![emoji1]
:oops: You see, that what happens when you drive all day long in traffic in the lower 48. You start seeing things. I'm going back to bed. :oops:
Barnstormer offline
In all truthfulness these things are what is so cool about this site. Look back and hopefully have a laugh...did I write that??? Hahahaha. Never happen on Facebook this way.
gbflyer offline
