Sat Nov 16, 2019 10:46 am
Good video. Good start to an important and valuable discussion of the Critical Decision Making process around EFATO. It's an especially tough decision tree to try to map out in advance due to the many and difficult-to-predict variables. Every second that ticks by, the scenario shifts and the "right" decision can change.
Whenever the question of if/when to attempt the "impossible turn" is discussed, the focus is often on "from what altitude" can I make it? There are several other factors contributing to "where are you in relation to a runway" when you reach that magic altitude AGL that you know you can make it from.
1. Runway length and surrounding obstacles. Departing from nearby Reno, with it's 9,000' GA runway parallel to an 11.000' airline runway, in a high performance plane, you'll likely still be over the runway when you climb through your magic altitude. Departing from the 800' sheep pasture in front of my house, it's well behind you.with challenges to getting back, but a big flat cattle pasture in front of you.
2. Climb performance in feet per mile (more relevant than FPM). This in turn being of course a function of
A. Aircraft performance for given configuration and weight. My 300HP 182 climbs like a homesick angel on wheels. Less so on the big amphibs.with a full load.
B. Density altitude.
C. Presence of updrafts or downdrafts.
3. Wind. Particularly in a mountainous area, wind velocity and direction can change just a few hundred feet above the runway.
4. No matter who you are, even Bob Hoover or Cool Hand Luke will experience a "WTF" moment when the big fan stops turning shortly after takeoff. How long your personal WTF moment is on that particular day will drive the decision-making process early on.
Point is, saying "I can make that turn back from "X" altitude doesn't matter if you're now already a mile and a half away from the runway with obstacles in between and your turn cost you a lot of altitude and you're facing much worse LZ choices than if you had kept the spinner pointed more or less straight ahead.
Great thing to think about every time from your home field and places you frequent. Google Earth or Foreflight and other tools can help plan in advance at unfamiliar fields.
Pierre
