hotrod150 wrote:akavidflyer wrote:The actual wording is 1320# MAX TAKE OFF WEIGHT not Gross weight (for wheels). I know one person who has succesfully argued, and won the argument with the FAA allowing him to fly his KF mod 5 (with a manufactures stated gross weight of 1550) under sport pilot rules. He just has to limit his max take off weight to 1320#. ...
First of all, please tell me the difference between "maximum takeoff weight" and "gross weight".
Secondly, per FAR part 1 (definitions), 1.1 (general definitions): "light-sport aircraft means an aircraft, other than a helicopter or powered-lift that, since it's original certification, has continued to meet the following:
1) a maximum takeoff weight of not more than ...(ii) 1,320 pounds (600 kilograms) for aircraft not intended for operation on water".
Note the "since it's original certification" qualifier in the applicable FAR.
If the KF 5 in question was originally certified with a gross weight of 1550# , I think that's that-- end of story. Unless it was intended to take off at only 1320#, then be aerial-refueled to it's 1550# gross.
Maximum gross weight is a structural limitation, Maximum take off weight can be a structural limitation, but more often than not, it is imposed for other reasons (length of strip etc.)
http://www.sportpilot.org/questions/afm ... ?faqid=415
The above link should spell it out very clear for you the definition of "maximum take off weight"
I am guessing that you have not dealt much with experimental aircraft... There is NO "certified" gross weight. Gross weight is what ever you decide to call it. The manufacture may reccomend 1200 # gross for my plane, but if I feel lucky, I can legaly fly it at 1700 if I feel the need to test it that far. The weight and ballance is the only place you will ever see a "maximum weight" on an EAB. The aircraft does not have to be registered as LSA to qualify.
