Toluene VS Buna N O-Rings?
Toluene is used in auto fuel for an octane booster but is not compatible with Buna N O-rings.
Where I get my ethanal free fuel the distributor says that it is 50ppm Toluene.
I haven't researched it yet.....but what's the deal?
A while back I had an o-ring swell up in my fuel selector valve, it restricted flow to about 12gph from one tank. Was it from the Toluene?
I test my fuel regularly and know I haven't run ethanol through it.
Does Toluene fit in with the auto fuel STC?
Terry offline
1365
- FindMeSpot URL: http://share.findmespot.com/shared/face ... 4GzPHI6t1d
Tue Nov 08, 2011 10:24 pm
Not airplane related, but I recently had buna-n o-ring problems in my powerstroke because the ultra low sulphur fuel would make them shrink/harden. I swapped them for viton o-rings and haven't had any issues.
ajfriz offline
125
1940 BC-65 with some mods.
1946 J3C-85
Sure glad you posted. Just think of the bad rap ethanol has gotten and probably as much or more the gasoline was the problem. I know of a fuel selector that has had E10 going through for almost 5 years and it doesn't leak. That o-ring is way older than 5 years also.
180Marty on Wed Nov 09, 2011 4:26 pm, edited 1 time in total.
2313
2313
Wed Nov 09, 2011 10:28 am
Viton (a perfluorelastomer) is fine in toluene. Kalrez is actually better, especially at elevated temps, but the cost does not really pencil out.
McMaster.com
I ran into the problem when folks were replacing the primer with the wrong o-rings- and made the primer unusable.
lesuther offline
1429
Wed Nov 09, 2011 12:29 pm
We use Viton 75 O-Rings in our Gascolator's specifically because of this exact problem. Viton 75 is impervious to all known fuels including straight alcohol, diesel, jet A, etc...
Brian.
Brian-StevesAircraft offline
759
You wonder why they even make the other kinds that aren't impervious to everything.
2313
http://www.marcorubber.com/material_chart.htmThis is a materials chart showing basic compatibility with fluids for the different compounds of O-Rings. Viton 75 is not very good for Steam or standard automotive type brake fluids.
If you really want to do your research you can go here
http://www.marcorubber.com/compatibility.htm and look up the particular fluid in the drop down list and see what rating the O-Ring is at for that fluid. On this list Viton A is listed as a #2 (scale 1-4) at a 10 to 20% swell for Toluene. Butyle is rated 4 - not recomemded.
Brian.
759
