Vick wrote:Something else to consider - can you get clean (ethanol-free) mogas where you are? If not, I'd be less enthusiastic about buying a Franklin. When I had mine I could get clean mogas, 10/gal/hr of mogas was very easy to deal with. The Franklin is certified for use with lead-free fuel and does not like 100LL. Burn it without adding TCP and you will stick a valve. If 100LL is you only option, when you factor in the cost of the extra fuel burn per hour (~2 gals ave) and the TCP you'll have to add there will be a difference - however marginal - in hourly operating expenses, not to mention having to lug the jug of TCP around with you, real PITA.
Vick wrote:You can probably google to find out if Colorado is an ethanol-mandated state. If not you should be good to go for now. If so you're SOL, thank your enviro-wackos and politicians...
mountainmatt wrote:Tadpole,
There's a gas station in both Elbert and Kiowa that have ethanol-free gas. The 165 Franklins don't prefer 100LL due to guides/valves sticking but run flawless on mogas. I have a few 55gal drums too.
The issue of the 165 working out of a field at 6000msl on a hot day... well, it just requires a bit more planning. I know of many people in the area that fly 100hp Cessna 140's and 145hp Cessna 170's, 65hp Champs, etc all summer long on 90+ deg days, but they pay more attention to the small things.
I've done more stuff in the CO Rockies with a 100hp C140 than some guys with a C182 would care to do, but like stated above, if you know your plane and know your skills you can stretch that margin of error a bit further.
And seeing Terry work his 165HC 108-2 in the ID backcountry I don't think the DA problem will be a HUGE factor.
Do I need the 220 Frank in mine... nope, but I'm glad I have it.
Small Tail Caddy wrote:Would I buy another stinson.....DAMN straight I would.....but I also have this craving for a maule.
