Always thought that rendering is what is done to a dead horse that has been sent to the glue factory.
Zane wrote:H264, 1280x720, 29.97 FPS, VBR 4 max 5, AAC 44.1MHz audio, single pass, render for quality
Littlecub wrote:Zane wrote:H264, 1280x720, 29.97 FPS, VBR 4 max 5, AAC 44.1MHz audio, single pass, render for quality
He accidentally typed in his system control password![]()
lc
swixtt wrote:do you have h.264 embedded in the software you use or do you convert it afterwards?
swixtt wrote:ZANE, THANKS!
Zane wrote:Do not use the highest quality original media format as mckim suggests above. Use the appropriate quality and compression for the usage, in this case web streaming. Vimeo and YouTube only require my above mentioned specs.
