Backcountry Pilot • The seldom-seen Bushwheel mudflap
29 postsPage 1 of 21, 2
Battson dug this one up earlier. I think this looks pretty cool, but not sure you could use it with such tight clearance in a low pressure bushwheel.
Re: The seldom-seen Bushwheel mudflap
Be good for scraping cow shit off the sidewalls.
Gump - that was what I was thinking we need back here in the cow pastures.
Zzz wrote:Battson dug this one up earlier. I think this looks pretty cool, but not sure you could use it with such tight clearance in a low pressure bushwheel.
Interesting question. Take a look at Gump's now famous landing. That was pretty intense, arguably about as intense as it could get as he can't be more than an inch or so from hitting the rim. Now look at the tire where this mud flap would be mounted. Even in that landing the tire at that spot looks pretty much the same as always. In particular, there doesn't seem to be any distortion causing the sidewalls to expand.
Further in the photo of the mudflap, it looks like the mounts for rubber are considerably back from the edge where the circumference would change due to centrifugal force.
Edit: Not Gump!!! OregonMaule.
rw2 offline
Aircraft: Experimental Maule
is that a recap... didn't know they recapped bushwheels... :?:
iceman offline
As far as I know, none of my famous landings have been captured on film... Yet! :D
lol.
Ok, we'll live with the one we have until someone finds the zapruder film from one of the others.
rw2 offline
Those aren't recaps, that ribbing is on all the Airstreak types.
I've explained in some detail to my rancher neighbors, in an effort to encourage proper fencing, how problematic it is getting cow shit off the bottom of the wing. Fresh cow shit, (or is that a oxymoron) and with a garden hose handy, not so bad. Well dried, and at least on my PolyTone surface, it takes fingernails. Maybe those super glossy paint jobs handle it better? My neighbors seem to be amused by this, and mention something called "open range". :evil:
I like those flaps, not sure how they work in some conditions.Image
I have no idea what video you're talking about, but whatever it is I'm eager to see it now.
rw2 wrote:Ok, we'll live with the one we have until someone finds the zapruder film from one of the others.
I don't think you have one of mine anywhere!!!!
Sorry guys, I'm a dumb shit on this one. OregonMaule is the one I was thinking of. #-o
rw2 offline
I think he might have Gump mixed up with Orygon Maule, There both pretty Ugly so might be hard to tell apart, just one flys a Cessna and the other a Maule :roll: They both have the same kinda attitude also =D>
Niether one of em are good lookin like me!! :^o :mrgreen:
M6RV6 offline
The tire bulge at the bottom rotates around the tire some, how far depends on the tire speed.
On Don's Stinson the brake caliper was mounted aft of the axle and rubbed his 8.50 tires. Moved the caliper forward of the axel and no more rubbing.
Terry offline
rw2 wrote:Further in the photo of the mudflap, it looks like the mounts for rubber are considerably back from the edge where the circumference would change due to centrifugal force.
Rw2, despite the Gump <> OregonMaule mix-up, I think you've made a good observation in that post.
The metal rod looks to be a good few inches or more clear of the tire, based on the location of bolts and AN970 washers. The rest of the gap looks to be rubber mudflap just hanging in there, which would give as the Airstreak flexed. This is a good observation rw2.
I guess that allows for the movement you're talking about Z?
The "mudflap" will not keep the wings clean of cowshit but it will help somewhat and will also stop stone damage to the tail plane. The "mudguard" will stop everything but will loose you 2-3 knots and are not approved. Despite that we had them on for 20 years with good results, apart from the small speed loss, which we could live with. Tyres are 8:50's
JamieG offline
Aircraft: C180J, O520
What paperwork was done for this mud flap? I'd like to fabricate and add something like this to my rig.
macica offline
Aircraft: Cessna TU206F
My mistake…
I thought these were the mud flaps you were talking about…
"Apparrantly there is nothing that cannot happen today."
Mark Twain
MS Pirate offline
Now those are classy :D
Aryana offline
Aircraft: 1955 Cessna 170
MS Pirate wrote:My mistake…
Mark Twain
I'm gettin some!!
After my camping trip to Mexican Mountain a few weeks ago, I came home to find another good ding in my horizontal stab. Much deeper than the last one. I know it's part of the price of where we play, but I just don't recall seeing a lot of this kind of damage on other planes at fly-ins.
So I was starting to wonder what can be done about it outside of the one expensive STC that is out there.
