Factoids: PA18 with a new wide deck 0320 (170+hp) & 41" Borer on EDO floats. After rebuild the tail is a bit too light.
My horiz.stab (trimmed to cruise) is a fair bit below center & I think that’s causing more drag, (pulling the tail down) right? A light tail is good for hauling loads, but 95% of my flying is just me, full tanks & permanent baggage. I made a 4.5# lead weight to bolt onto the tailwheel bolts & went up (without it) and marked speeds @ each 100 rpm diff.
Then I hung the 4.5# on the tail & it made NO diff. in speeds. Damn. Trim is a bit higher, but still below center. I wonder about the droopy tips, ya think they would make the AOA higher? I’ve heard that they cause more drag, & I think higher AOA in that they’d trap more air under the back of the wing @ the tip. I dunno, but my tail is trying to dive.
Fuel burn goes up about .5 gph for each 100 rpm, except from 2200-2300 & from 2600-2700 it jumps about 1 gph.
Speed goes up about 5 mph for each 100 rpm. 2200 rpm = 80 mph, 2800 rpm = 110
2200, 80 mph it burns 5.6 (US) gph. 2500, 95 mph it burns just over 7. 2600, 100 mph it burns over 8.
What I didn’t do was adjust the mixture each time but I don’t think that would change it much @ a fairly constant altitude. A bit I guess.
Anything you can think I could do/try or just leave it & be happy?
