Wed Nov 02, 2011 12:08 pm
No oxygen, mountains or turbocharger required at all, if you are willing to simply make a little dog-leg in your course. Fly down into the US southbound, staying east of the Rocky Mountains and the high ground. Make your way south and west through the Dakotas, Kansas, and into Clovis New Mexico. Then fly south to Carlsbad New Mexico. Continue south and turn right at Interstate Highway 10, follow that into El Paso TX, then through southern New Mexico, Arizona, and into California. Interstate 10 passes about a mile away from KUDD airport. As you get near Bermuda Dunes there will be a very pretty 10,000 foot mountain right in front of you (Mt. San Jacinto), but you will not have to get close to it, over, under or around it unless you want to go all the way into Los Angeles.
This detour will probably cost you a few hundred miles extra compared to a straight line. But the added benefit of this method is safety... you stay closer to roads and populated areas, flat ground, stay out of more icing or bad weather, etc. Being too close to the downwind side of a major mountain range (like the Rockies) in strong winter/spring winds can be a dangerous situation because of lee wave and rotor. If you choose the Albuquerque route, be advised that you might want to stay east of the mountains until you get to Interstate 40, then follow 40 westbound. I would not recommend a straight line through the desert from ALBQ to UDD, it's some pretty desolate country, lots of small mountains, and not much in the way of help if you have to land somewhere between ALBQ and PHX.
Of course you can fly southwest to Laramie Wyoming and follow Interstate 80 through the hills to Salt Lake City, which is not that awful as far as mountains, but if mountains are something you don't like then it may not be the best way..
