Michelin Tire home page:
http://www.airmichelin.com/Skygeek sells tires and has pics so you can see them all. Nice.
http://www.skygeek.com/tundra-tires-and ... tires.htmlFor the Experimental folks, Mickey Thompson Drag Slicks
https://www.mickeythompsontires.com/strip.phpWell, that's about it for me. I'm sure there are many other dealers and parts providers, but this is just what I found to read up on the subject so that I am not quite so lost when somebody says
"...yeah I have 29 blimps with a 337 and no STC. I didn't need a DAR at the FSDO from the FAA if its on the MX5, unless I use the Airstreaks, then Whoa..., cause the field approval would be hard, because there is no TSO on that baby, just check Atlee and ask about PMA's on the McCreary's, but I really like the Condors on my 6's with Clevlands, but I cant use the 3 bolt, Why not?, because of the dang 337 that I still need a copy of from you, and ANC FAA doesn't even use the Tunrda Tire Worksheet anymore, can you believe that?"
What the?
Good Luck, I hope this has been at least some help to you.
Like I said, just a document link thread. Not a shoppers guide or anything.
No debates. Just a list of documents to educate yourself.
