uncle_rob wrote:I fly a C-150, and am still learning (about 50 hours). It's got a row of rivets down the center of the cowl. If I lean over into the center of the cockpit and look down that row it seems to me that it should be pointing right where I'm flying.
But...to make it do that I have to apply right rudder. No big deal, yaw is to be expected. The thing is, when I think I'm flying straight the ball is no longer in the middle. When the ball is in the middle it feels and looks like I'm crabbing.
Can this come from the rudder trim, is the turn coordinator out, or am I imagining the whole thing?
What that row of rivets.....
....is really good for is making perfect steep turns without ever once looking inside the airplane! I forget which seat one needs to be in for the proper turning perspective. Been a long time since I was an active flight instructor in C-150s. Any how turning one way in a 45 degree bank....keep the row of rivet right on the horizon. Turning the opposite way....keep the curve of the engine cowling right on the horizon. You won't gain or loose a foot.
It you sit in the other seat then the rivets and cowling reference are swapped for direction of turn. Seem to remember that it is the cowling going clockwise and the rivets going counterclockwise in the left seat. But not sure. One way or the other.
Try it. You will be amazed.
From the days before GPS, glass cockpits and magic stuff....when pilots were taught to fly by looking outside.
Bob
