Be advised that uAvionix has come out with a service bulletin,
mandating an update for the software in their SkyBeacon & TailBeacon ADS-B units.
https://uavionix.com/tailbeacon-softwar ... s-b-1-5-1/
JP256 wrote:Doesn't it apply only to the tailbeacon?
Ardent wrote:Good to know, I still have my kit in the box.
mtv wrote:
Just upload the SB thingie on a computer, and load it when you do the setup. Easy, and I am NO tech wizard, believe me.
mtv wrote:JP256 wrote:Doesn't it apply only to the tailbeacon?
No, applies to both SkyBeacon and TailBeacon. I installed it today. Took a lot...maybe three minutes.
StillLearning wrote:can it not be done from the phone you set it up with?
Bigrenna wrote:....You guys have to actually READ the SB. The units all use the same firware, but this SB is only for the tailbeacon installed under STC SA04427CH. Greg-
hotrod180 wrote:"qualified installer" (kinda like an asst manager at McD....
StillLearning wrote:If I can’t do it with the app I set it up with, then I guess it won’t get done.
I looked again, it says it requires a pc with windows 7 or newer.
Not impressed, until now I liked the simplicity of the tail beacon.
