Battson wrote:I have tried to contact Hartzell about this, but no word since.
Can anyone explain how to make sense of Hartzell P/N's. I get some of it, like the number of blades, the hub/blade, length, and the R or L rotation, but how can I tell if it's a climb or cruise prop etc?
E.g.
Hub / 84" Blade: HC-C2YR-1RF / F8475R
The 8475 spells out the prop diameter (84) and blade pitch (75).
Think of the pitch as the distance forward the prop would move in one rotation if it were rotating in a bowl of jello, or if it were a screw, being driven into some media. So a 75 pitch is more of a "cruise " prop than say a 44 pitch would be. This is all effective pitch, since this is a constant speed prop and the blades will change pitch in flight.
If the designation were followed by a "dash number", ie: 8475-4, the dash number implies that in this case, four inches have been cut off the base prop, reducing the diameter, usually for a different application. These props are often used on numerous aircraft, with different diameters as appropriate.
