Bonanza Man wrote:
The A36 gets 210 kts true at 17,500, the 210 is known to be a 190-195 knot airplane. The real downside to the whole deal is the insurance on a 210 right now is twice what the Bonanza is. The simple fact of the matter is it is raining C210 parts from the sky. For this year as well as the past decade the accident rate of the 210's is double that of the Bo. This year alone there have been 26 accidents and 13 fatal accident in 210's vs 12 and 5 for the Bo. It is such an alarming trend that the Cessna Pilots Assoc has an article about it in this months magazine. No matter what the type of mishap the 210 comes to grief twice as often as the Bo and they have similar fleet sizes. You Cessna guys have a serious pilot training problem.
I am not sure where you are getting any of your numbers and you are comparing apples to oranges on your speeds. Lets look at the numbers on a side by side comparison...I will use the numbers published in the Aircraft Bluebook Price Digest to keep the playing field level as it seems to have to most exhaustive references.
The fastest NON TURBO model of the A-36 is the 300 hp with a max speed of 184 kts. and recommended cruise of 169 kts. The Bo also has a MGTOW of 3,650 lbs and a useful of 1,430 lbs dry.
Apples to apples the fastest NON TURBO 300 hp C-210 is the R model with a max speed of 175 kts. and recommended cruise of 170 kts. The 210 has a MGTOW of 3,850 lbs and a useful of 1,630 lbs dry.
Based on that information the Bo has a higher max speed, but a lower recommended cruise and a lower useful load by 200 lbs.
Now lets compare your favorites...the Turbo models
The fastest model of the A-36 Turbo is the B model with 300 hp...is has a max speed of 213 kts. and recommended cruise of 190 kts. The Bo also has a MGTOW of 3,850 lbs and a useful of 1,512 lbs dry.
The fastest model of the T-210 is the R model. To be completely fair the T-210 does not come in 300 hp like to Bo, the only options are 285, 310, & 325; but we are wanting to compare the fastest of each manufacture in their category. The T-210 R has a max speed of 224 kts. and recommended cruise of 207 kts. The T-210 has a MGTOW of 4,100 lbs. and a useful of 1,780 lbs dry.
If you would like to compare the lower horsepower (slowest) T-210 with the highest horsepower (fastest) Bo then your numbers are a little more accurate. The 285 hp T-210 is the F model and it still has a max speed of 200 kts and a recommended cruise of 191 kts. The T-210 has a MGTOW of 3,300 lbs. and a useful of 1,333 lbs dry.
As I stated in a previous post...the 210 will outrun and out haul any Bonanza in the same class. Oh I did not mention that the C-210 is also offered in a Pressurized model, but that would not make an apples to apples comparison.
Not sure where you get your accident numbers either...according to the NTSB report in the US between 1/1/07 and 8/8/07 there have only been 18 total accidents reported on the 210 of which only 4 were fatal meaning the survivability rate on these accidents was 78%. The Bo on the other hand for the same parameters had only 6 total accidents of which 3 were fatal meaning the survivability rate for the Bo was only 50%. Now obviously this is only covering 8 months worth of time frame, but it is apples to apples and the picture is not near as bleak as you make it sound.
To keep the accidents in perspective we must also get an accurate picture of the fleet sizes and the total fleet hours of each aircraft...they are not as close as you seem to portray. According to the FAA registry currently in the US there are 2,815 registered various models of the Beech 36 as compared to 5,772 registered various models of the 210. The size of the currently registered 210 fleet is more than double that of the Bonanzas so we would expect a higher accident number although it is actually a lower per aircraft rate than that of the Bo.
By the way...apples to apples the insurance rates are not double on a 210 than they are on a Bonanza...more: yes but nowhere near double. Only part of the higher cost comes from the accident rates, but a major factor is that they are not longer factory supported so new parts are hard to come by and repairs can become costly.
1975 Beech A-36 valued at $150,000 with PVT / INST / 1000 PIC / 500 M&M would in the $2,000 - $2,400 ballpark annually.
1975 Cessna 210 valued at $150,000 with PVT / INST / 1000 PIC / 500 M&M would in the $2,800 - $3,200 ballpark annually.
Either aircraft is a good choice depending on your mission profile...for my mission profile the C-210 win hands down, but for others the Bo is the blue ribbon winner. It all comes down to needs and wants...what do you need and what do you want from your investment. Each has pro's and each has con's, but choose the one that best fits YOUR needs and not the needs of your buddies or you will not be happy.
