Using food coloring to test for alcohol in gas
Mon Dec 17, 2012 12:38 pm
Stol offline
1048
Tue Dec 18, 2012 10:20 am
I was gonna buy some food coloring yesterday at the grocery store, $2 for an ounce, but I noticed that it comes in a little jar with a standard mouth. Seems like unless you use some sort of attachment on the jar, or an eyedropper, it'd be pretty hard to add just a drop of food coloring to a test container of gas without making a big mess. How are you guys doing it?
10535
Tue Dec 18, 2012 11:06 am
The $2 red food coloring I bought at the grocery store had a snap lid top that dispenses drops. You can see it in the photos. Try a different store for another brand of food coloring?
Karmutzen offline
711
Tue Dec 18, 2012 11:14 am
A cap like in your pic would work fine- guess I'll have to shop around a bit. The QFC (Kroger) store I went to had 2 different brands & both appeared to have just screw-on caps. I figgered red would be the easiest to use. ??
10535
Tested my gas samples again today and photographed the results. The food coloring was purchased from Safeway Stores at about $3 for the four little containers. Three drops in each gas sample. The jar on the left is 87 Oct with alcohol, the jar on the right is 91 Oct with no alcohol. Just filled my 76 gal tank today with the 91 Oct from the local Cenex filling station.
All is well!!
1667
Wed Dec 19, 2012 12:25 pm
I don't see any coloring in the RH jar. Is it in a little blob at the bottom?
10535
Wed Dec 19, 2012 12:43 pm
Yep in bottom can see in my photos
tcraft offline
297
shawn coleman
2202T
tcraft f-22
hotrod150 wrote:I don't see any coloring in the RH jar. Is it in a little blob at the bottom?
Yes there are three drops in each..can barely see the little droplets along the bottom of the glass. When I shook the jars the drops broke up into very tiny droplets but did not difuse into the gasoline.
HC
1667
