Backcountry Pilot • UV rays VS: fuel hose
6 postsPage 1 of 1
My fuel hose is hung on a tire rim on the dock. Sun shines on it. Any ideas how to keep the UV off of it without having to build a box over it? Visible @ front of house so can't be an "eyesore".
NimpoCub offline
Re: UV rays VS: fuel hose
NimpoCub wrote:My fuel hose is hung on a tire rim on the dock. Sun shines on it. Any ideas how to keep the UV off of it without having to build a box over it? Visible @ front of house so can't be an "eyesore".
Slip a fire hose over it??
M6RV6 offline
I built a little tin shed, the same color tin as the hangar it is outside of, for my 300 gallon bulk tank, and I keep my 30' refueling hose in it, under the tank so out of the sun. I like that the tank is also shaded, as that may help with evaporative losses? I took a neighbor flying the other day, and as he was watching me put the hose away, he (who is in the fluid handling/hose business for commercial industrial uses) commented "you need a takeup reel". That would be sweet but a couple hundred bucks at least I'd guess, and I'd still want to keep it out of the sun.
I did build a shed over my bulk tank, buried the hose to the dock, but it's exposed where it hangs on the rim. Can't have the tank near the lake. I think what I'll do is find some UV resistant material & make a Superman cape to hang over it. Sheathing the hose would be too bulky to hang on the rim. What is Superman's cape made of?
NimpoCub offline
NimpoCub wrote:I did build a shed over my bulk tank, buried the hose to the dock, but it's exposed where it hangs on the rim. Can't have the tank near the lake. I think what I'll do is find some UV resistant material & make a Superman cape to hang over it. Sheathing the hose would be too bulky to hang on the rim. What is Superman's cape made of?
SPLIT FIRE HOSE?? :mrgreen:
M6RV6 offline
We've got this stuff we put over our hoses, but more for anti-chafe where they're dragged on the ground. It's almost like a gore-tex material that velcros together around the original hose. Maybe you can get something like that made for cheaper than a new hose every few years?
6 postsPage 1 of 1
